oopsy59
Old 05-22-08, 08:57 AM
oopsy59
2000 Chevy Blazer with 6 cylinder full power. Problem with fuel gauge swinging from full to empty. In the past I had another older model pickup 1986 that had the same problem It was the circuit board connections behind dash instruments. Does anyone know if 2000 model gm vehicles have the same setup? If so what is the cure. If not what is the cure? Thanks in advance OOPSY59
Old 05-22-08, 10:23 AM
ukrkoz's Avatar
from chevy forums i found that it is usually negative contact on sending unit in fuel tank. needs to be cleaned and reconnected.
i am not saying it's not circuit board. just sharing what i found.
Old 05-22-08, 02:09 PM
will try easiest and cheapest route first. The negative wire would be the easiest over getting into the circuit board.Thanks OOPSY 59
Old 05-23-08, 12:12 PM
ukrkoz's Avatar
not on my truck, though. said to have truckbed removed to get to the wire. (silverado 1500)
you welcome, friend, and good luck. let us know how goes it.
Trackbacks are On
Pingbacks are On
Refbacks are On
