97 Lumina stalls when letting off gas
Received 0 Votes
Hello, I don't have any sollutions but my 97 Lumina is doing the exact same thing and my husband and I can't figure it out.
Last edited by HotxxxxxxxOKC; 05-23-08 at 07:17 PM. Reason: Removed email address.
Received 0 Votes
Has I.A.C / A.I.S. motor been checked, cleaned, replaced ? It's one of the common places to look when those symptoms occur. It's a solenoid on your throttle body that controls idle speed during different driving conditions. Sometimes you get lucky by just removing it, give it a good cleaning, and re-install.
from experiences with several japanese imports, various makes: locate EGR valve, remove it, and clean with spray injector cleaner. reinstall. be careful not to damage gasket. they are usually fairly easily accessible. look it up either in manual or local library.
also, check your air filter. pull it out and shine flashlight through. light should shine through easily. or look at the sun through it.
