code 55
Received 0 Votes
code 55
96 Eclipse 2.0 non turbo. I been having an intermittent stalling that has gotten worse in the last week. It first started in Dec./ Jan.. The eng. runs fine Then it won't idle but will run if i feed a little gas. then let it sit over night and it runs fine. [Its done this cold or hot eng temp.] Yesterday I cleaned the IAC and throttle body. It was fine for 15 or 20 miles. then it stalled again. today its idling fine. I did the key on offon off on and CE light blinks 5 times pause 5 blinks. the book I have don't list 55. Also get this at some point someone changed the cam pos. sensor and only put in one bolt Its a 10mm hex head bolt any idea what size mm the thread is? Also I've looked for bad vac. hose can't find any leaks. Thanks in advance. Thank You to all our men and women in uniform past and present. Happy Memorial Day.
Received 0 Votes
After cleaning the throttle body and IAC the prob. got worse. I read through posts and went to the eng. code sites. some said code 55 IAC. The book I have said 25 to 30 ohms res. mine read no res. so did the new one. I replaced the IAC 5 days ago and its been fine so far.
