Transmission Fluid '00 Ford Windstar
Old 05-26-08, 12:16 PM
N
I have a 2000 ford windstar and I cannot find where to add transmission fluid to it. Can anyone please help?
Thanks,
niceguy4u36
Old 05-26-08, 02:07 PM
hiflyn72's Avatar
Thanks,
niceguy4u36
Just pour it down the dipstick tube.
Old 05-26-08, 02:53 PM
like to add
Like to add pour it down the transmission dipstick hole not engine oil. Use a funnel.
Old 05-26-08, 03:11 PM
Unclediezel's Avatar
If you cant find the dipstick, you have no buisness adding fluid to the unit.......Overfilling these units is just as bad, if not worse ,than running them dry.
Some Ford products are "Factory -Fill " units, in which case there will not be a Dipstick. I dont know for sure but 2000 seems a bit early for this type of setup.
Look under the hood, drivers side... At the transmission. You should see a "Black Pipe" about 3/4" in diameter. Follow it up and you will see the Handle for the dipstick. (Usually a YELLOW "RING".)
