1999 Chevy Malibu pulls to one side
Old 05-26-08, 04:25 PM
msidan's Avatar
I'm considering this car and when I test drove it, it pulls to the left side very slightly. The rear left tire has significantly less tread than the other tires and will need to be replaced. Could that cause the pulling to one side? Or perhaps low tire pressure?
Old 05-26-08, 04:53 PM
Speedwrench's Avatar
check the air pressure on all tires, check and make sure that all of the tire sizes are the same, then test drive it again. if it still pulls swap the two front tires to rule out a tire problem. most likely the front needs alignment.
murphy was an optimist.
