1998 Grand Voyager - indicator light
Received 0 Votes
Hi,
I changed the front driver side indicator bulb but it still does not work. The bulb seems O.K . What do you think the problem is . The local mechanic feels it may take three hours of trouble shooting to repair it!!!
Any help is appreciated.
Thanks in advance
Thanks in advance
It should be a pretty simple circuit to diagnose. You need to determine if you have power and ground to complete the circuit to illuminate the bulb. If you arent going to diagnose it yourself, then it should not take a technician more than an hour or so to diagnose such a simple circuit considering based on your description it seems the left side is the only side that is inop.
Hope this helps ya,
Billy
Hope this helps ya,
Billy
