Speedometer doesn't work, help!
Old 06-03-08, 04:21 PM
G
Have a 1996 Dodge Neon, the speedometer doesn't work. I know on the older cars all you had to do is replace the cable. Does this Neon have a cable to replace or does something else control it?
Old 06-03-08, 04:40 PM
Unclediezel's Avatar
Nope...no cable.....
Its all electronic , thru the PCM.
Just a pet peeve about Neons......Look at the battery tray. The battery shifts slightly to one side, and PINCHES the PCM harness, and possibly knocks the Power distribution Center..(Thats a Fuse Box To you and ME..) off of its mounts. The first thing to go is the speedo, and likely a Check engine light.
Just a guess, but if yours is like the 95% majority, its worth a shot.
