Air conditioner fan problem
Received 0 Votes
I have a 92 Buick Le Sabre in good condition with low mileage but just recently the heater/A/C fan does not turn off with "OFF" button or even when the ignition is off, and key is removed. It'll keep going full speed and drain the battery so I removed the 30 amp A/C fuse. What is my problem?
Received 0 Votes
would probably check your blower motor relays under the hood to see if one is sticking just giving it a light tap may be all thats needed to unstick the relay but it should be replaced to keep it from hapening again.
