98 dodge caravan a/c belt replacement?
Anyone have directions and diagram for replacement of the A/C belt for a 1998 Dodge Caravan ?
thanks
thanks
Here's a link that will put you in the neighborhood. Get to the engine you have, then run through the "how to info" for belts. You may have to use a guide for an accessory other than the AC.
http://www.autozone.com/servlet/UiBr...3d8005035e.jsp
There should be a sticker on your support above rad, or underside of hood, or somewhere under the hood, or fender areas that shows you the proper routing of the belt. Which engine? Does it have just the one serpentine for everything?
