1997 Ford Escort dies
Old 06-09-08, 11:41 AM
My 97 escort started dying a week ago when pulling out of driveway. Now it dies while driving and especially at stoplights. It restarts with key.
Any clues on what it may be? I replaced the fuel and air filter, plugs and wires last September.
Old 06-09-08, 03:26 PM
mikeTN's Avatar
Smile
check/clean air intake where air enters engine. check throttle pos. switch/or equivilent. check ALL vacuum lines(both ends) for cracks/loose fit. replace as necessary. it is a start!!
Old 06-09-08, 04:26 PM
Good answer Mike, also, look under the throttle body there is a vac hose there the often gets missed. Many a Ford mech made his days wage with charging a customer many hours for this 2 min fix.
Old 03-02-09, 12:00 PM
idle
I am having the same problem 98 escort dies out
Old 03-02-09, 12:50 PM
the_tow_guy's Avatar
Good idea to check fuel pressure, too; may be a weak pump.
Old 03-02-09, 01:18 PM
If I was a betting man, I'd be checking the PCV line........rubber boots/ends on plastic tubing.......The end going into the manifold ALWAYS collapses and splits.....The 90deg boot from an old spark plug wire is the un-"official" fix
Old 03-02-09, 04:33 PM
nightowlpunk's Avatar
You might want to check for water of snow in the air intake and air filter. My Jetta was running wicked rich and stalled out a few times. Turned out snow went into the air intake and melted resulting in water being where it shouldn't.
