silverado window problem
Old 06-09-08, 02:16 PM
2001 chevy silverado passinger window only works sometimes, asks like its binding. motor gets really hot.
Window motor is only 1 year old.
any ideas as to what might be wrong.??
Old 06-09-08, 02:24 PM
mikeTN's Avatar
Question
since you said the motor gets hot, i presume you have the door panel off. does the motor get hot running by itself? disconnect the window regulator and operate the motor and see if it gets hot and check the window manually to see if it is hard to raise/lower. there could be a problem with the wiring if the window goes up/down ok by hand and the motor gets hot by itself.
Old 06-10-08, 02:15 PM
window
thanks, I had thought about trying that but wasnt sure what it might determine. I will try it in the next couple days and post results.
thanks for reply.
Old 07-06-08, 07:01 PM
window
thanks for help, I tried it without the window, it clicked and stopped, bought new motor and seems to be working fine now. The one I took out was a new one, must have just been bad from start.
thanks for the help mikeTN
Trackbacks are On
Pingbacks are On
Refbacks are On
