2001 cadillac window
Received 0 Votes
How do I remove the door panel on the passenger side of a 2001 Cadillac Deville? The window is off the track but I cannot figure out how to remove the panel without damaging the door.
Received 0 Votes
regulator
there is a plastic clip on the regulator that breaks on these all the time it is a really bad design. however there should be a series of screws and 7mm to get that panet off start with the handel and then move to the window switch there should be 1 or 2 under that as well after you find all the screws there will be a few panel clips that will pop off easily don't bother taking the panel off though till you have the new regulator.... pain in the butt job you may want to pay some one for this
