2001 Chevy Suburban
I replaced the rear brake pads and the emergency brake shoes on my 2001 suburban. Problem is now I have too much play in my emergency brake pedal. I checked the cable adjustment underneath and it is set all the way back. The emergency brake holds fine but you have to press it down more than 1/2 way to get it to hold.
Is there any other way to adjust the cable or the emergency brakes?
Thx.
Thx.
Was there a "STAR-WHEEL" on the parking brake mechanism? If so it adjusts the same as conventional drum brakes. If not , the cables are probably stretched and should be replaced.
Star Wheel
Yes - I believe there is one. I do know that it screws in and out because I had to adjust it in to make the end of the emergency brake shoe fit slide down over it. Do I need to take the rotor off again and adust it or should I just go get a new cable? You're probably right that the cable is stretched a little. Thx for the advice.
Probably not, there should be a rubber plug on the backing plate , that gets removed to access the star wheel. Tightening the star will likely help drastically, Since cable stretch would need to be extremely severe to cause what youve described.
