Timing Chain Repair 98 Dodge Grand Caravan
Received 0 Votes
98 dodge grand caravan - drove 3-1/2 hours to airport...went inside for 30 minutes...when leaving airport - pulled up to stoplights...stepped on gas - the van sputtered and died...when pulled over, tried to restart...sounded like a loud tractor...wouldn't stay running. hasn't started since. acts like it wants to start, but won't turn over. timing chain???
fuel pump hums when the key is turned on. it's getting spark on all 6 from the coil pack. help please???
thanx
thanx
That'll be a belt rather than a chain. The "loud tractor" sound doesn't match with a broken timing belt. Neither does sputtering and dieing; when the belt breaks it would be "poof" and it's not running anymore. What you should get is a very rapid cranking - weeweeweeweewee - due to the loss of compression resistance on some cylinders.
The trctor noise you describe sounds more of a "Rod" knock, than a Cam timing issue.
Compression test may eliminate or confirm the chain issue, But without more info...Its just a guess. "Check the Motor Oil"!!!!!
Received 0 Votes
thanx
thanx
Certainly one possibility. Fuel pump, too; just because it hums doesn't mean it's putting out enough pressure/volume to support engine operation.
The "sounded like a loud tractor" symptom is a little puzzling.
