wipers not working
Old 06-18-08, 08:06 PM
T
wipers not working
i have a 1993 camaro Z28 with 19,000 miles wipers dont work, fuse is good , do you have any ideas what could be wrong besides wiper motor & fuse
Old 06-18-08, 09:14 PM
Speedwrench's Avatar
you will need to be able to test or bypass the switch to see if the problem is the switch or the wiper motor. a 12volt test light will let you check for power to the switch, unhook the conector and probe for power to the switch.
if we're not supposed to eat animals why are they made out of meat?
Old 06-19-08, 03:23 AM
T
wipers not working
the switch is on the steering colum how can i test it ? the cruise control is also part of the lever
Old 06-20-08, 07:18 AM
R
Received 1 Upvote on 1 Post
GM has had a lot of trouble with circuit boards cracking in the wiper motor lately. RW
Old 06-20-08, 04:27 PM
Unclediezel's Avatar
Beforee racking your brain....look out under the hood, at the wiper motor itself. One of the mounting bolts will have a "GROUNDING" tab under it. Make sure the bolts are tight, Start the car , turn the wiper switch to hi ,and try "Tap And Wiggle" . if the motor sparks and the wipers react, clean the ground tab, and reinstall.
Old 06-25-08, 04:15 AM
T
Thumbs up wipers not working
Fixed it was the wiper module $290 mostly labor Thanks to all the mechanics who replied to me, i appreciate it
