Need help with airbag
Received 0 Votes
Received 0 Votes
I'm guessing that this is an age-related problem. One of the connectors is corroding or developing tarnish, which increases the resistance in the circuit. If you have a way of safely checking the connections, you may find the problem. Sometimes just a disconnect/connect will give a fresh conductive suface at the connection.
I thought Ford increased the threshhold from 2 to 4 ohms. Back in 91, Ford was experiencing a lot of false positive air bag lights due to this problem. I know that because I was working at Ford at the time.
