Diagnostic Code 97 Civic
Received 0 Votes
1997 Honda Civic LX 5 spd
Engine Malfunction Light
OBD II #135 O2 Sensor Malfunction
any idea what this is?
and cost to repair?
is this something that I can do or does this have to go to a Honda shop?
Thanks for your advice
TD
and cost to repair?
TD
Havent checked, but if I recall, that is a failed o2 heater.
Determining which sensor.......You definitely have at least 2, possibly 3 or 4....is the trick....
Any reputable shop can take care of this for you...it does not need to go to honda.
If you can, have it scanned again , and get the position......
sensor 1 is before the cat, sensor 2 is after. Replacing the sensor itself is a matter of unscrewing it and installing a new one, but you must check the heater circuit wiring on the proper sensor position before continuing.
