Check engine light
Old 06-22-08, 04:11 PM
Check engine light
1996 Ford Contour Sport....68,000 miles.
In the last about 3 months, on 2 occasions, the check engine light came on, and stayed on for about 2 to 4 days, then went out on its own. It went out yesterday, after the most recent "on" stint.
A few years ago, there were check enging issues, and I think ultimately they replaced the O2 sensor. Can't remember if they replaced the catalytic converter.
Before I take it in for more expensive work, is there anything in particular that would be a suspect for this intermittent condition?
Old 06-22-08, 04:35 PM
Gunguy45's Avatar
Super Moderator
594
Any codes? I mean from Autozone read or anything? Sounds like it could be as simple as a gas cap.
Old 06-22-08, 07:49 PM
I hadn't thought about having Autozone pull a code....I did hear that they can do that. I will go check the gas cap right away. Might buy a new one just in case. Thank you very much.
Old 06-23-08, 04:50 AM
the_tow_guy's Avatar
I would hold off on buying anything until you get it read, although gas cap would be on the list of likely items.
