keyless entree not working
Old 06-29-08, 07:30 AM
I have a 2003 Dodge Durango SLT and the keyless entree is not working. it's not the batteries. The horn goes off but the doors will not lock or unlock.
Old 06-29-08, 07:41 AM
HotxxxxxxxOKC's Avatar
Try to reprogram them using these steps, if it does not work, you might need the dealership to swap the transmitter box.
Program Method A (Customer Program Method)
Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
Turn ignition to run position. (Allow ignition chimes[UNLOCK] to stop).
Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTEFOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
Repeat steps 5 through 6 to program additional transmitters.
Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Program Method B (Customer Program Method)
Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
Turn ignition to the run position (Allow ignition chimes to stop).
Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
Turn the ignition to OFF position to exit the transmitter programming mode.
Courtesy of Dodge
Old 06-29-08, 08:54 AM
Unclediezel's Avatar
Before going any further, Ensure the "Power Door Locks " work properly with BOTH toggle switches on the driver and passenger doors. If the horn sounds on "Lock" attempt, the vehicle is recieving a signal from the key fob, but is unable to actuate the locks.
Old 06-29-08, 08:59 AM
Gunguy45's Avatar
Super Moderator
Unc and Hot, what about just a fuse? I know if the interior button operates, then that wouldn't be an issue.
Old 06-29-08, 09:39 AM
Im not positive, but I believe P/L's are on a breaker. That is however where I would go if the locks were inop inside the vehicle.
Old 06-29-08, 09:40 AM
billys68ss's Avatar
Do you mean the horn beeps when you press the lock or unlock button on the remote? If this is the case then its most likely a problem in the door locks and not the RKE functions. Do any of the doors unlock or lock? Do they lock and unlock with the bottons on the doors?
Hope this helps ya,
Billy
Old 06-29-08, 03:49 PM
all the lock bottons work on the inside but not with the remote.
Trackbacks are On
Pingbacks are On
Refbacks are On
