1995 Plymouth Voyager
Old 07-01-08, 11:05 AM
W
starts fine but when put into drive or reverse engine stalls. What can be the problem, van has new trans with 15,000 miles. No lights or codes come on.
Old 07-01-08, 03:07 PM
Unclediezel's Avatar
Pull the intake hose off of the throttle body...Inside you will likely find a Black "Tar Like" substance that Must be cleaned out......A can of Gumout, or even aerosol Brake cleaner will usually do the trick.....Just make sure you use the "LIL RED STICK" and get up into the IAC passage.....The extra rectangular hole in front of the throttle blade.
Old 07-01-08, 05:53 PM
W
stalling
Just as if you popped the clutch? Torque convertor locked up.
