middle brake light
middle brake light
91 olds cutlass cirea
the middle brake light(the one above the trunk) does not light. it takes 2 1141 bulbs. however these bulbs arn't made anymore. does anyone know what model bulbs would work. its a single filament with one metal contact. the dome says use 1141 bulbs only.
Mine didn't light because it had a corroded socket because of a moisture leak.
Lamp manufacturers like GE and Sylvania, or auto parts stores, can cross reference this number to a new bulb.
Brake lamps should pull way more current than dome lights . . .?
They're still made. Might want to try couple of differencet stores:
http://www.bulbtown.com/1141_MINIATU...ASE_p/1141.htm
They're still made. Might want to try couple of different stores:
Advance/Discount Auto has them on line, so check their store if you haven't already:
http://www.partsamerica.com/ProductD...artNumber=1141
autozone had them in the store on the shelf. whats weired is i went to there website looked up 1141 and the bulbs came up but it said not avaible online or in the store
could it be cause the package says 1141LL
