1994 Ford Escort
Old 07-06-08, 02:53 PM
A
1994 Ford Escort
How Do I Get More Fuel To My Injectors, In Order To Start My Car.
Old 07-06-08, 04:15 PM
Received 37 Upvotes on 36 Posts
Most fuel injection systems rely on the water temp sensor to tell the computer to send more fuel for cold starting. Assuming you have good fuel pressure and clean injectors, that usually does the job.
Those aren't too expensive and can be replaced DIY.
Old 07-06-08, 05:49 PM
W
First thing to look for is the impact switch............Shuts off the fuel should the car be involved in an accident...........They can trip on a big enough pothole or other less than smooth object in the road
Look in the passenger kick panel and in the trunk........
Old 07-07-08, 04:33 AM
the_tow_guy's Avatar
Received 262 Upvotes on 213 Posts
Backing up a little, exactly what kind of symptoms are you getting? Your post is a little general.
Old 07-07-08, 03:52 PM
E
Received 1 Upvote on 1 Post
Also, from the wording of the post, one cannot tell if he simply wants to troubleshoot, by seeing if he can figure out a way of adding gas as you could with old carbureted cars, or even throttle body injectors.
