Point gap and dwell
Old 07-14-08, 03:59 PM
Point gap and dwell
what is the diff. between point gap and Dwell, and what if you set the gap only?
Old 07-14-08, 04:28 PM
6 of one half dozen of another
They are two ways of expressing/controlling the same thing, the amount of camshaft rotation that the points are closed.
Set one per spec and if all is well the other will follow. Used points will be pitted, so a feeler gauge is harder to use. Set the dwell if you have a meter. A larger gap should yield a smaller dwell.
Old 07-14-08, 05:55 PM
Thanks for the reply, that is what I was thinking, I am a ford man and alwys set the gap only, but my boat engines have a gap and dwell setting and I never really asked the question before.
Old 07-14-08, 11:29 PM
The dwell is a more acurate way of setting the point gap basically. You can go either way, but just setting the gap can be hit and miss. I probably haven't set either in probably 15 years or more.
Old 07-15-08, 03:55 AM
I still own a few things with points in them one of them being my 1988 Carver, I have thought about converting it to solid state but enjoy the reliability of points, I mean they can always be filed and reset in the event of failure, however when the pointless dist. fails you better have the tools and new module or you are dead in the waterand calling for a tow if you have only one engine that is, but outside of my toys I have not set points in years also.
Old 07-15-08, 07:06 PM
billys68ss's Avatar
Point gap is the the distance between the contacts on the point set. Dwell is the amount if time the contacts are closed. These 2 items are adjusted totally separate. You can adjust either without affecting the other. The gap is adjusted with the points on the highest point of the cam. Depending on the design of the engine the cam will have multiple points equivalent to the number of cylinders. These cam lobes open the point contacts firing the ignition system.
The dwell is where the contacts open in relation to the spark plugs wires location on the distributor cap. This location can be changed by rotating the distributor while it is installed in the engine. This can be understood better by a BTDC (before top dead center) or ATDC (after top dead center) dwell setting. If your engine requires a setting that is not perfect 0 degrees the dwell must be adjusted. This means the ignition system does not fire when the piston is exactly at top dead center.
Hope this helps ya,
Billy
Old 07-15-08, 07:27 PM
Unclediezel's Avatar
I realize its the same thing when you get to the "Nitty -Gritty" ...But what Bill has just described is Ignition Timing.
Much Kudos.....I was never able to time a motor with a dwell meter......
Did you keep the points in your Chevelles???????
Old 07-16-08, 04:04 AM
billys68ss's Avatar
Well... actually they are not the same thing. They are two totally separate settings. Yes they go hand in hand, but dwell is essentially the fine tune timing of the ignition system. The point gap is just that a measurement across two contacts. If you dont have the point gap set correctly it will never fire properly. ie hot or cold fire.
Nope, threw out the old points distributors and put in new HEI units. Gutted and ground the gear off of the old points distributor and use it for priming new oil pump on fresh rebuilds. Stick a drill on it and away it goes.... oil geyser...
Billy
