Oil Pressure Fluctuates
I just started noticing that the oil pressure in my Tahoe is fluctuating.. even if I start it up in the driveway when I hit the gas it goes up from 35 to 60.. My Caddy doesn't do it..My Oil level is fine.. do I have a probelm?
I do not see a problem with the oil pressure, most engines oil pressure will vary from idle to road speed. The engine will survive with as little as 15psi at road speed, so if you have 60 psi when you rev it up you should be fine.
