Anti-Lock warning light
Old 07-16-08, 12:47 PM
I have a 2001 Buick Century and today I took the car out and while driving I notice the Anti-lock warning light was on, the brakes seem to work alright so is everything else. Is this pretty expensive to fix? Appreciate your help. Thanks
Old 07-16-08, 03:30 PM
Unclediezel's Avatar
Yellow light only???? No red brake warning?....
If it is only the yellow, Then The ABS system has detected a problem and disabled the "Anti-Lock" function.....Conventional service brakes are still fully functional....No need to worry just yet....
Now to answer your question......MAYBE...
The wheel speed sensors are a common failure point on GM "A" bodies..Century , Ciera, And many of the Malibus. The wheel speed sensor is an Integral part of the Wheel Hub and bearing assembly and must be changed as a unit.....A Repair shop and a Scantool will be necessary to verify this , and also to determine which side of the vehicle is affected...Left or right, front or rear....
By no means will I tell you to Ignore it, but There really isnt an Immediate danger or hazard at the moment....
Old 07-17-08, 10:13 AM
Unclediezel, I appreciate your help very much. Thanks a lot.
