Inside fan problems
Old 07-18-08, 03:06 PM
Inside fan problems
2003 Dodge PU. When either the heat or Ac is on the fan motor works great through all 4 cycles on the floor. When switched to the dash or defrost the air floor becomes very restricted.
Old 07-18-08, 05:32 PM
billys68ss's Avatar
Please explain what you mean. Do you have air coming from the vents or the defrost when that mode is selected? Do you notice any difference when you select recirc?
Billy
Old 07-19-08, 05:41 AM
Well sounds like your switch isn't workin properly. Have you checked your fuses? Maybe your motor that moves the plastic piece that directs air flow is binding up on something? Can you hear movement when you switch from one position to the next? More info bout your problem would help. Be more specific
