Turn signal help
Received 0 Votes
Turn signal help
I have a 2000 saturn LS2 and my turn signal either does not work or works briefly.
Received 0 Votes
the blinker comes on briefly and turn off or it does not blink
Received 0 Votes
The switch feels the same as before
Received 0 Votes
Yes. Left and right behaves the same. The problem got progressively worst in the past month, i.e. the indcator would work for about 15 seconds before it switched off. Now it may work for 2 seconds or does not work at all.
Ok. Sounds like your switch lever (multifunction switch). Should be a fairly easy replacement. Just remove the plastic shrouds around your stearing column, and the lever should just be held on by 2-3 screws.
The part itself can run about $100-200. Might want to try a junkyard first.
Received 0 Votes
