sliding power door
sliding power door
I need to know how to change out a power door motor on a 2002 Dodge Grand caravan passenger side.
Thanking you in advance
This is a pretty simple task. Remove the Door panel and the watershield. The motor is right in the center of the door. It will have 4 "push pins" that are holding it to the door panel. These pins will most likely break when you pop them out. Dont worry about it. If you purchased the new motor from a dealer it will come with new pins. The cable slides out of the motor very easily. Simply reinsert the cable and stap the new motor into place.
Hope this helps ya,
Billy
Hope this helps ya,
Billy
