Wheels frozen to axle
I'm trying to rotate my tires but they are completely frozen to the axle and won't budge!
What's the best way to break them loose? (and yes, I did take the lugs off first)
Received 0 Votes
Loosen each wheel nut about 1 to 2 turns and drive the vehicle into some hard corners and using the brakes hard. This should loosen the wheel. Obviously do this where you can do this safely and do it at low speed.
