95 Escort Wiper/AC Electrical
95 Ford Escort LX Wagon, The wipers (front and back) has no power getting to the inside fuse panel the washer motors have no power. The AC/ heater blower has no power at fuse panel. the AC fuse block under the hood has no power. All fuses look and test good all other electrical devices are working fine.
Heater breaker is working
No burnt wire smell
No Idea What Happend
No burnt wire smell
ford has a bad habit of useing fusible links to protect some systems, look under the hood for a short wire comeing from the battery or starter solinoid and give it a tug if it streches it is bad.
life begins when the kids leave home and the dog dies.
same
Looked for a fusable link all the wires I can get to are in great shape The car starts and runs great just no wipers or AC. The Haynes Wire diagram shows someting called a wot that th AC wires attach to, What is this and could it be the prob?
Contact your Local ford dealership.....
I dont know if the escort was included, but there was a Massive recall for Ignition switches catching Fire. The Terminal that feeds the wipers also feeds AC function and Rear defroster.......At least take the column covers down and look at the harnesses
WOT usually refers to Wide Open Throttle. It kicks your a/c out for the added horsepower when hammering the throttle to pass or whatever. Some 4 cyl engines were noticeably sluggish with a/c on, and tended to get some people unexpectedly in trouble trying to pass, thus, this was, I believe, incorporated to help with that.
Would that Ignition lead be a black/w red stirpe? This wire is showing no voltage in the on or off position. The rest of the wires/terminals are working. My Haynes manual is very limited on diargams
There is another post somewhere on this forum where the issue was very much the same (wiper and AC are tied into the same relay) and the guy was able to isolate what it was. Check out all other post on this site and you'll come across it.
The Fix
Here is the fix
Replaced the ignition switch and everything works great.
Ingnition 2 was burnt in the switch so no power was going into wipers, washers, rear defrost or AC/heater blower
$40.00 part, 15 minutes work ( I've replaced 1 before)
Thank for all the hints
