Strange question
Received 0 Votes
Strange question
I have rebuilt my 350 Chevy engine and I have some pieces left from the build. I want to make a coster from one of the pistons however, this means that I will need to separate it from the skirt. I only want the top of the piston from the top ring. What tool would be the right tool for cutting threw a piston? I believe it to be Aluminium however, it could be cast iron. It's a stock piston if that helps anyone.
Thanks
-Nate
Thanks
-Nate
I have seen a piston with the rod , made into a small clock. They put the clock works from a hobby shop in the rods big end.
After the piston was skirt off. I have seen them made into a small wall clock.
Received 0 Votes
Well i cut threw them with a hacksaw. It took 2 hours for 1 with a dull blade then an hour for the other with a new blade.
Thanks for the advice guys.
Any idea for a project with a camshaft?
Nate yer way too obsessed...2 hrs? jeez..Next time use a sawsall and a file to clean it up.
Weld a base on the cam, then put one of the other pistons on top...standing ashtray....or grind the guts out of the piston and push in a koozie and its a beer holder for the porch.
