95 Windstar ABS groaning
Old 08-04-08, 06:36 AM
My 95 Windstar ABS system has a groaning from the front under the hood when brakes are depressed. The ABS light only comes on occassionally and doesn't stay on. Would this groaning be the ABS sensors needing to be cleaning, or would I have to look deeper into the ABS module? The brakes work great and no vibration or pulsing in the peddle. I'de hate to have to replace the module as it would cost more than the van is worth. If the contacts just need to be cleaned, how would I go about taking them off and cleaning them? Does the rotor have to come off to access the sensors?
Old 08-04-08, 04:28 PM
Unclediezel's Avatar
Quick check.....
In the underhood fuse block.....Remove the ABS fuses....Drive the car...If the symptoms are resolved....Look carefully at the "Tone Rings" around the CV axles......One of them will be Cracked or Chipped.
If you can verify this, the fix is to replace the Offending CV axle..
Old 08-04-08, 04:41 PM
Originally Posted by Unclediezel View Post
Quick check.....
Will give it a try tommorrow and get back to you. Thanks for the info.
Old 08-05-08, 12:01 PM
Quick check.....
Took the fuse out as you suggested and the noise from the ABS is gone and the brakes work fine. Now, however, the ABS light in the dash stays on. The old van has 297000 on it and I really don't want to replace the whole CV shaft if I don't have too. My question now is; can I disconnect the light in the dash by pulling the wire to the light? Or is it a transistor operated light? In which case, I'm just going to black out the light with a piece of black tape.
Trackbacks are On
Pingbacks are On
Refbacks are On
