trams am problem
Received 0 Votes
trams am problem
I have a code 26 guad driver fault set on a 1993 trans am. How do I diagnose the problem? There are no other codes set and the engine runs fine. The only other issue is a rich exhaust.
without a data stream view, you probably cant.
A quad driver is a section of your ECM , designed to handle High Current loads. These would include TCC, EGR solenoid, Cooling fan relay. etc.... There are 4 of them, (Hence the term "QUAD"), Designated by letters A Thru D. Without access to a data stream reading for which "Letter" has failed..your limited to grasping at straws , one at a time, until you find the failed component.
Logically, The Wiring to the EGR should be checked first, since a short to ground will trip a quad code, and an open EGR would cause a rich exhaust.
Received 0 Votes
I have a snap-on scanner so I can view the data stream. what should I be looking for? When I first aquired the car it had a code set for the EGR and an O2 sensor. I replaced the O2 and cleared the codes. After driving a couple of times the Quad driver fault appeared with no other codes. All the discriptions I have just dont show how to find the exact problem.
