idle adjustment 1.8l subaru xt multiport fuel injection
Received 0 Votes
just replaced the intake gaskets on my 1990 subaru xt and now i cant get the idle to go below around 1600-1800 rpm, its almost like it just doesnt kick down even though it is fully up to temp...it also has a self diagnosis function in the ECM and it flashes five times and no description in the repair manual for five short flashes.....
HISSSSSSSSSSSS
sounds like you either have air leak(and a major one) into the system, or one of the vacuum lines is diconnected/damaged, letting air in.
re-inspect every sigle vacuum and air line for tightness, cracks, kink, damage.
as of leaking gasket - if that's the case - i, honestly, donno how to spot it, as it's sucking air in, not pushing it out.
Received 0 Votes
well before i replaced the intake gaskets it wouldnt hardly run at all,wouldnt idle, and ran very rough...now it seems to run smooth , idles fine (except fast) i reason i suspected the gaskets was discoloration around the gasket area..i'm going to double check/replace vacuum lines tomorrow and see if that helps...
Received 0 Votes
i'd say im good remove and replace mechanic, with a few other bits of info sprinkled in...in other words, i'd say i can probably handle whatever your going to suggest if i cant i have some mechanic type ppl i know..
