Keyless Rmote 99 Infiniti QX4
Old 08-12-08, 01:03 PM
My keyless remote started working sporadically. This is my second remote. I ordered a new one but when could not program successfully. I followed the instructions, I put the ignition key in and out 6 times in 10 seconds and the turn signal indicator lights flashed twice. I then turned to key to acc and pressed a button on the remote but could no get the confirmation of lights to come in. Could there be a problem with the car programming?
Old 08-12-08, 03:07 PM
HotxxxxxxxOKC's Avatar
Did you make sure the "FCC" code on the remote matches the factory OEM ones you had? This FCC code will be different sometimes within models. This FCC code will also be on the module that controls it, which is usually under the dash somewhere.
Old 08-13-08, 06:29 AM
Yes, the FCC codes matched. I am thinking I may have a problem with the receiver in car.
Old 08-13-08, 08:20 AM
Dougmo, I'm thinking that you may be right about the receiver, but I don't know of any test procedures. One thing to check would be to see that all connectors are tight, and maybe disconnect and reconnect them in case any corrosion is preventing proper operation.
Old 01-18-10, 12:49 PM
Keyless start problems...Please LA Times.
My name is Ralph Vartabedian and I'm trying to contact consumers who have had problems operating their keyless push button start systems on any model cars. I'm a reporter at the Los Angeles Times. My email is [email protected]. My phone number is 213-237-3393. Thanks.
Trackbacks are On
Pingbacks are On
Refbacks are On
