1992 Dodge Caravan Engine Bracket (Mount?)
Hello everyone.
I am going on a 12 hour trip from Seattle to Northern California and have very little cash.
I was told the engine bracket (mount?) is broken on my Dodge Caravan 1992. So when I stop it clunks.
Does anyone know if this is really expensive to get fixed? And also, do you think I would be able to make it to my destination with this problem? I would much rather fix it when I get there because I am strapped for cash. The engine runs fine and everything else is great on it.
I might get a second opinion first, but if it's needed I would get it changed before, to eliminate the possibility of damaging other parts of your powertrain such as transmission, which would be very expensive. Not sure where you are but around here you should be able to have it done for $100 or less, for part & labor.
