no brake pedal
Old 08-18-08, 02:55 PM
V
Unhappy no brake pedal
A friend has just finished a brake job on a car. There is no brake pedal. He has done many brake jobs and this is the first time he has experinced this issue
Old 08-18-08, 04:01 PM
Received 786 Upvotes on 689 Posts
Welcome to the forums!
Front or rear brakes? or both?
Did he bleed the brakes? check the brake fluid level?
Old 08-18-08, 04:14 PM
E
Received 1 Upvote on 1 Post
There is much that has not been told to us. Like - if he drained the master cylinder dry while bleeding, does he know about bleeding the master cylinder? Did he put in a new master cylinder or were there symptoms IT was the thing that was bad, to begin with? Did he preadjust the rear (drum?) brakes to get them to gently rub, or didn't he do any adjusting at all? Were any of the rotors or drums extremely severly worn down? Does he know about brake bleeding sequence? (Who knows, maybe he has just lucky in the past, depending on what he did with brake jobs)
