2003 Alero
2003 Alero
Wife has a 2003 Alero that is leaking rad fluid from the over flow hose when engine is turned off,Heat gauge shows it is running at normal operating temp any ideas??She also told me AC quit working on last trip for about 300 miles then started working again
Is the catch jug over full? Check the level in it when it is cold, should have a cold full mark on it. As far as AC it might have frozen up. Is it working now? Is it working properly?
Test/replace radiator cap. AC may have frozen up due to atmospheric conditions ( extremly high humidity cool temps). If it stops working again I would have the system checked to be sure it is charged properly. Sometimes an under charged system will freeze up
