88 ford broco won't idle
My 88 bronco at first would lose power, so I had the oil changed, which didn't work. Then it cut off and I had to be towed home. I replaced the fuel filter, and it would run, but not idle, so it would cut off. The fuel pump works, as it is flooding fuel and you can smell gas. I was told it could be the air fuel injection valve, and I replace that, but now it won't even run at all. Could this be the plugs? what is wrong?
Check all your vacuum lines to see if any are cracked and leaking. This could be a possible for a twenty year old vehicle. This was the case with my '83. I bought a spool of tubing and replaced them all.
Casey
"http://www.driverdb.com/Sean McDonagh"
Casey
