94 Z24 Cavalier turn signals
Old 08-28-08, 01:02 PM
I have a 94 Z24 cavalier. The turn signals starts off normal but will slow down and sometimes stop working. Then I have to do it manually. All bulbs are fine and I just changed the relay under the dash. Any suggestions what to do next?
Old 08-28-08, 06:06 PM
Next time, pull the lever back and hold it while the turn signal is on. Your bright lights will blind some people, but your turn signal might work better. If it does, your turn signal switch needs to be replaced.
Old 08-28-08, 07:07 PM
Thanks I will try that next
Old 08-29-08, 09:03 AM
Tried holding the bright lights on like suggested. Turn signals still not working properly. Any more suggestions?
Old 08-29-08, 04:37 PM
It's as if when heat develops from current flow, the current flow reduces (as in voltage dropping off).
I'd say you need a wiring diagram to see where all the connection points, are so you can do some voltmeter tests while it does this, to see where you still have fuill voltage, and at what location it drops off.
Trackbacks are On
Pingbacks are On
Refbacks are On
