1993 chevy z71 no power to ac compressor
Old 08-31-08, 10:52 PM
Should I get power to the compressor clutch by turning the controls on inside the truck?Used a test light and turned the ac on but not getting any power to the compressor.Is there a relay that sends the power if so where would it be located?
Thanks for any information.
Old 09-01-08, 06:00 AM
Is the system charged? Check for power at the low pressure cut off switch, located on the reciever dryer( silver tank on the firewall passenger side with 2 lines going in it). If you have power there and comp wont run check the charge in the system, if charge is correct replace switch. The switch is on a Schrader valve so you wont loose the charge if you take it off.
