isuzu rodeo
Old 09-06-08, 06:28 AM
F
isuzu rodeo
hi i just bought a 1997 isuzu rodeo but i cant get the back seat to lock in place is there a way to adjust them so it will lock in place, and how hard would it be to change the head gaskets myself thank you
Old 09-06-08, 02:13 PM
Speedwrench's Avatar
v 6 or inline 4 on engine?
if we're not supposed to eat animals why are they made out of meat?
Old 09-06-08, 02:47 PM
E
Received 1 Upvote on 1 Post
It might help everyone here if you say if you ever changed head gaskets in anything, so one can know your skill level and understanding of certain procedures that are going to be pretty much the same in any vehicle.
Old 09-06-08, 06:07 PM
F
it is a v6 n i have never changed head gaskets myself but could posibilty do it myself if was told how to
Old 09-06-08, 07:36 PM
F
and he car only has 90,000 miles on it could it be they are just that the bolts have became lose
Old 09-06-08, 07:37 PM
you can do it with a good shop manual but you must follow all of the procedures very carefully or risk needing a new engine, you can't skimp on tools or procedures when doing this type of repair. If you don't have the proper torque wrenches and other tools suggested by the manual then either buy or rent them. it would also require the services of a automotive machine shop to check the head for flatness and cracks. that being said it might be cheaper to find a good local shop to do this. just check references carefully
life begins when the kids leave home and the dog dies
Old 09-06-08, 07:40 PM
with 90k miles you will not be able to just torque the head bolts and reseal a head. that is a 50 to 100 mile thing. the expansion and contraction of the head is what wears out the head gasket and sometimes they don't last as long due to manufacturing tolerances.
Murphy was an optimist
Old 09-07-08, 10:13 AM
F
weel about how much would most shops charge to do it
Old 09-07-08, 01:49 PM
labor wise should be about a 4 to 5 hour job, plus parts, however that could be $ as what if a head is bad?
Old 09-09-08, 01:49 PM
F
ok i have another question the radeo has a dule over head cam v6 it seems if i rev it a little alot of water comes out the tail pipe is this normal or is there a problem i should be worried about thank you
Old 09-09-08, 03:10 PM
E
But does it still expel water after say 15 minutes or more of driving? Or have you mainly noticed that at cold morning starts when idling car? And what is your outside air temperature where you are at, while you have been noticing that?
Old 09-09-08, 05:51 PM
F
well it does it when i first started it up it was about 90 degress today when i didi it i dont think it does it after about 10 minutes
Old 09-09-08, 07:21 PM
fast, that is your catalitic convertor working properly, when the vehicle reaches proper opperating temp the water exits as vapor usually invisible.
life begins when the kids leave home and the dog dies.
Old 09-10-08, 03:30 AM
F
thank you for all the help speedwrench
