Starts right up & Immediately dies.
Received 0 Votes
I have a 1997 Town & Country LXI that has had this to happen a couple of times, I was told to take the battery cables off, and to hold them together about five min., to clean the battery post real good replace the cables, wait about ten min and try starting and it worked just fine, (No problems) after about 3-4 weeks it did the same thing again, I then let it along for about 12 hours and it started right up, now no problem. Could someone HELP Me with this, I can't trust it now.
Received 0 Votes
These sporadic problems like this can be hard for anyone to find as things wil test out with testing equipment if it is working at the time. You don't now if it is fuel or electrical, either.
Yes, it is scary if you plan on trips or whatever and have no idea if it will strike again. Likely always to happen when out in tinbucktoo somewhere at 3 in the morning.
You can have someone try to bring up codes. I guerss they do it for free at places like AutoZone and Advance Auto to name a couple places.
And often 'service bulletins' will list a problem like this if the same malady has struck many cars of that type and year. You could look into that by even contacting maybe the service manager of a dealership and hope the person is friendly and may tell you.
I'm thinking you could have an ignition switch issue.
Do you have a GRAY colored ignition key? Did you recently have duplicate keys made for the vehicle? are they also Gray in color?
Is there any form of magnet on your key ring? (Not likely , But it has happened)
It Sounds as if your PCM is not getting a "VALID " key signal.....
