Loose Steering on 1979 Camaro
I have a 79 camaro and the steering feels very loose on the highway. I checked the outer tie rod ends and the left side has a noticeable amount of verticle movement. Would that be the sole cause of the looseness? How do I check the inner tie rod ends, centerlink, and idler arm for wear? What are the chances that and inner tie rod, center link, or idler arm is causing this problem?
Thanks,
Jon
Thanks,
Jon
Was there an imporvement after the rebuild? I was thinking about replacing the coil springs and the control arm bushings as well.
Thanks,
Jon
Thanks,
Jon
life begins when the kids leave home and the dog dies
