GT6 repair-clutch
This may be a stupid question but I am going to ask it anyways-Is clutch fluid the same as brake fluid therefore can brake fluid be used in the clutch master cylinder.
Canadian tire does not seem to carry clutch fluid?
Just one note...make sure you use the correct DOT rated fluid.
Some are compatible w/each other, others are not.
See here, about 1/2 way down......
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
