1998 Dodge Neon Gas Fill up Leak
Old 09-13-08, 07:54 AM
C
Hi, I have a 1998 Dodge Neon with about 80,000 miles on it. When I get gas, it leaks as I'm putting it in. I looked and can see that it's the hose from the gas cap to the tank. Looks like someone before me had the same problem and patched it. I want to replace it because it looks like it's just 3 screws by the gas cap, a wire harness, and a hose clamp to the fuel tank. My question is, What is the name of that part? I tried typing several different things on auto part sites with no luck. If I had the correct name, maybe I can get one. Thanks for your help.
Joe
Old 09-13-08, 08:13 AM
Joe,
I am pretty sure the part you are looking for is called a fuel filler neck hose or fuel tank filler neck. Hope this helps. Good luck with your repairs.
Jon
Old 09-13-08, 08:35 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
It may be a Dealer only part as well.
I did find this....http://www.1aauto.com/1A/FuelTankFil...-/-/1AFMX00014
But they don't say if there is rubber included. It looks like all metal.
Theres a couple of Chrysler mechanics that will prob check in later.
Old 09-13-08, 09:35 AM
Speedwrench's Avatar
when you change out the filler neck hose make sure you don't dislodge the vent hose,
murphy was an optimist
Old 09-13-08, 04:55 PM
Unclediezel's Avatar
stop at your local chrysler dealer....
The parts guy will be able to show you a picture.....Pick out the parts you need and have them ordered.
Not impossible...but I doubt you will find these aftermarket...Do not attempt to use a radiator hose!!!!!!!
The wiring harness is probably for something else, and only Clipped onto the neck.
