1992 Ford Aerostar Suspension help
Old 09-14-08, 12:00 PM
T
I've been getting this clunking noise from the right wheel when ever I would go over bumps.So I replaced the stabalizer links, they needed to be changed anyway. But that didn't stop that clunking sound. So I examined the area better and found the problem, the bushing is completely off on this bar. It would be greatly appreciated if you could tell me what is the name on this bar? also do I need to buy the entire piece or just the bushings,
Here is a link to a pic I took of it.
http://www.flickr.com/photos/65938288@N00/2853247727/
Thank you
Old 09-14-08, 12:31 PM
it looks like your sway bar and if it is you can get a repair kit for it at your local parts store. You might take to the parts store and they could tell you for sure. Hope this helps you
Old 09-14-08, 01:10 PM
T
The bar is about 8-10 inches long, so I don't think it is the sway bar, but thanks for the reply.
Old 09-14-08, 01:16 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
No, not the sway bar. Crapola, my old cars had something like that, but I can't for the life of me remember what its called.
Ahhhh found a ref pic here.....its just a bushing, if still available looks pretty cheap. Doesn't look like the bar itself has a number assigned.
http://www.teamfordparts.com/partloc...layCatalogid=0
Old 09-14-08, 01:18 PM
T
Yeah the number 3 one looks exactly like it, I wish they had a name for it. I want to make sure to get the correct bushings for it.
Old 09-14-08, 01:28 PM
Gunguy45's Avatar
Super Moderator
#3 is just the shims...the bar isn't numbered. Guess they figured it would never break?
Well, when you go to the dealer, they'll be able to pull up the diagram. Looks like it stayed the same for a long time. Don't think you'll need the bar, just a new bushing. Hopefully you can just jack it up to take the pressure off and loosen the nut, and replace the bushing.
Pretty sure you'll need an alignment afterwards.
Old 09-14-08, 01:29 PM
Unclediezel's Avatar
That my friends is a Control arm......
Just a personal opinion....Have it fixed professionally......
Reason being this.....Those bolts go all the way down thru the subframe. Removing them requires support for the frame, otherwise, the frame drops and the bolts dont go back in...... A lift and a tripod type "SCREW JACK" are sort of a necessary evil for this.
Old 09-14-08, 01:47 PM
Gunguy45's Avatar
Super Moderator
UncD
All that, just to replace the bushing, really? Yer kidding?!! I mean, sure I understand if you had to replace the whole arm or mounting plates, or if something was broken.
But can't he just take the nut off the end and replace the bushing? Uh, I mean it is a 16 y/o van (no offense Tman, lol).
btw...I knew it was a part of the upper control arm, but I sure didn't know if that one bar with the threaded ends and holes had its own name. Does it?
Old 09-14-08, 02:18 PM
T
Yeah I thought just removing the bolt on the end and shoving in a bushing would work. I hope it doesn't require all that work, or for me to take it in for repairs. Then it really wouldn't be worth me keeping it. The motor is still good on it and the tranny works good.
Old 09-14-08, 03:35 PM
Unfortunately, The bushing doesnt get knocked onto the arm, But rather into the "End Cap". Look at the vehicle, and without removing the end caps, The shape of the arm doesnt permit removing the arm without disturbing the caps.....
This is a been there , done that, experience that I dont wish on anyone...Although.....three 2 ton floor jacks and a bunch of patience does sound tempting...
UM....I dunno honestly.... Control SHAFT?????
Old 09-14-08, 03:47 PM
T
What might happen if I just leave it like that?
Old 09-14-08, 03:59 PM
Gunguy45's Avatar
Super Moderator
UncD
I get ya a little better now. That rubber doesn't compress very well unless it's in a 10 ton press I bet. Gotta be honest, I'd be damn tempted to use lots of silicone lube and some C clamps to try. Couldn't make it much worse.
Course, I pulled engines with a tree branch and a come-along...so thats just me.
Heck, prob turn out that the bushing isn't even available separately.
Old 09-14-08, 04:26 PM
Eventually , the end cap will distort and tear, and the arm will fall out of the cap. this leaves you with no steering control, and a wheel that either tilts out and rips the fender, or worse , falls IN and pushes up thru the well into the passenger floor.
Old 09-14-08, 04:42 PM
T
Okay thanks for letting me know, I think I'm just gonna park it. Bike here I come, LOL
Old 09-14-08, 04:43 PM
Gunguy45's Avatar
Super Moderator
Gotta be fixed one way or another. It's unsafe.
Old 09-15-08, 09:46 AM
T
I've got one more question, I was wondering if it might be a bit easier of a job if I was just to purchase the entire control arm with the bushings already installed in them. I've changer control arms on my car I use to have. Plus if I run into any problems I do have a repair manual for the vehicle.
Old 09-15-08, 02:47 PM
Yes and no....
You wouldnt have to contend with pressing the bushings, but your still stuck with ..."How to get the bolts out Without dropping the frame to the concrete..."
