Paint Removal From Outside Rearview Mirror
Received 0 Votes
I have a 2004 Toyota Camry. While I was pulling into my garage, I scraped against the side of the garage. Luckily, my outside rear-view mirror was not broken, but there is a lot of white paint on it. It seems to be made of some sort of plastic. Has anyone had any luck with removing this exterior housing paint? If so, what did you use? I appreciate any help.
If the plastic is shiny I have used TR3 wax on these kind of things before and it seems to get the paint off. Use a damp rag and the wax, and rub HARD.
Received 0 Votes
IMO, I've had good results with Meguiar's ScratchX which can be found at most convient stores such as Walmart, Pepboys, Target. It is a mild abrasive which cleans out the nooks and crannies and removes the paint. As an added bonus, if the scratch isn't to deep (when you run your fingernail on it, it doesnt catch) it does a great job hiding it.
