1992 ford F150
1992 ford F150
How do you get to the front running lights or side lights of this truck. It is burnt out and dont want a ticket. Thanks
you will have to pull off the chrome trim around the head light assembly, it should be held in place by two screws on the top you can access with the hood up and four more screws that you will have to look hard for, two are on the bottom almost covered up by your front bumper, also it will take a little tugging to get it to come out. just look carefully for the screws, by the way they might be size 15 torx on that year.
some times autozone web site has the right info on replaceing bulbs and such you might surf there and look at replacing bulbs for your model.
Murphy was an optimist.
