honda cr-v heater
Old 09-17-08, 07:02 PM
honda cr-v heater
I have a 2005 Honda CR-V. Just recently purchased it and first time I turned on heat, blower works but temp is just lukewarm. A/C has been working fine. I recently changed the cabin air filter but don't think that has a bearing on this issue since a/c works. Any ideas?
Thanks
Old 09-17-08, 07:10 PM
Speedwrench's Avatar
welcome the the forums,
first thing to check is the coolant low? low coolant is probably the no 1 reason for lack of heat. next is does your blend door open fully, does your temp guage show full temp? if the temp guage doesn't show full you will need to check or replace the thermostat. check these things and get back to us.
life begins when the kids leave home and the dog dies
